Robzimbo
- Dec 4, 2016
Advice, please, friends.
The vehicle: 105 series, I HZ engine, 'Standard' (base model) Spec, manual box, manufactured 1998, 155,000 kms. Front discs, rear drum brakes.
The problem: I start up the car. Manoeuvre out of a parking space, forward or reverse, a bit of hard lock, slow speed, drive a hundred meters or so, tap the brakes, and there's a really nasty 'grab' from somewhere in the transmission line, or possibly the brakes. It feels MOST like the diff lock is on, though there's no light showing on the dash.
OR it feels like the handbrake is 'grabbing', but I think it's ok after we checked it.
It's definitely from the rear axle / hubs / brakes. Probably the Right rear. Which is why I was sure it is connected to the handbrake. But now I'm not so sure.
I had the vehicle up on a lift yesterday, had the handbrake and brake shoes checked. All seemed mostly ok (though there's a small oil leak from the right rear drive shaft seal, and the adjustment was way out, so we sorted that out).
When I rotated the right rear wheel in forward direction the left rear wheel rotated in the opposite direction (though at a slightly slower speed), which suggests to me that the diff is not locked.
When it's done this 'grabbing' thing a couple of times, at the start of a drive, it's fine thereafter. But if I stop for a few hours, and start again, it does the same thing.
Is it possibly connected to the leaking drive shaft oil seal? A small amount of drive shaft oil could be pooling in the brake drum when the vehicle is standing... but I can't imagine how that would translate into this "grabbing" feeling.
Any thoughts and comments would be most appreciated.
Best regards
Rob
Nairobi
Best regards
Rob
Nairobi
