Turbo pressure fault
Szlovi
hungary
Hi,
My car is a KDJ90. In a town or a mixed use there is no problem with it (up to 1000 miles) but in a highway after few minutes check engine signal is light up and the power reduced. After a quick stop it’s working again for a while. In the fault code store 34(3) number is stored. I've changed the turbo pressure sensor, the turbo pressure valve but the problem is still there. Is it a turbo (mechanical e.g. geometry changing) problem or maybe the turbo geometry changing motor problem? Please help!
