OK, first, personally I wouldn’t recommend you going as big as 35”
Given the constant of 18” diameter rims, your current rolling diameter is about 31”.
If you keep the width the same (265mm) but go up to 70% profile (you have 65% at present) you’ll have a rolling diameter of about 32”.
If you go a bit wider to 285mm, with 70% profile, you’d get a rolling diameter of 34”.
I can’t guarantee they wouldn’t rub mind, but some others might be more familiar with what matches with a 2” lift.
@ nielsc
Shagged maybe original suspension and 305/70 R16 Toyo Open Country on a 16x10 et -32 rim . These tyres recommend a max rim width of 9" so on a 10" they might be about 32" tall , for me me they are the ideal rim size for the 80 though everyone has there own preferences .
View attachment 141926 View attachment 141927 View attachment 141928 View attachment 141929
