Vehicle Kit
Hi Chris,
I've just had a rear bumper & wheel carrier fitted by 4x4 R US
http://indigo.xilo.net/~landrove/ra...ufacturer_id=0&option=com_virtuemart&Itemid=1
They were very helpful in mounting the receiver hitch (included with the
bumper) within the bumper rather than below it as was their original
intention until I said I would prefer it within, so increasing the ground
clearance, they were happy to do that, they also fitted two 'feet' to rest
the wheel on when lifting it into place on the carrier, one thing I was
disappointed about was that they used 12mm bolts to mount the wheel instead
of the standard size wheel bolts (I'm not sure what size that would be) but
it meant normal wheel nuts could not be used. If I had known beforehand I
would have raised an objection. All in all though I am very pleased with
it, it is very tough, I backed into a lamp post without a mark on the
bumper, the swing-away release handle is very easy to use, total cost
was£1200 but I also had front & rear diff guards fitted at the same time.
TTFN
Chas
London UK '94 1HDT 80 Auto, 114500+ miles, Safari snorkel, Rocksliders,
Maggiolona roof tent, Engel fridge, Custom Winch bumper & winch
----- Original Message -----
To: <[Email address removed]>
Sent: Sunday, November 16, 2008 8:32 PM
Subject: [ELCO] Vehicle Kit
I am looking for some advice, the Frogs Island cargo barrier - is it easy to
remove and replace or is it a semi or permanent fitment.
Any body have opinions on rear wheel carriers - ARB or Kaymar??? Quality of
the steel, the actual swinging bracket/bearings, tow hitch receiver etc????-
other makes?
ARB or TJM Bullbars? Other? - advice as above
West Malling, Kent
96 TLC 80 1HD-FT Manual - about to start prepping.
Sorry Chaps, that link didn't work. try this one
http://indigo.xilo.net/~landrove/rangiebreaker/
TTFN
Chas
Sent: Sunday, November 16, 2008 9:38 PM
Subject: Re: [ELCO] Vehicle Kit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Hi Chris
I have the carrier that bolts to the rear wing and as Julian says it does
have its issues.
The locking mechanism is a little fussy and not reliable at times.
You can not buy parts for it and the rubber block fitted to the tailgate
wears out or falls out.
There is no restriction on the swing arm at all and with the weight of the
wheel and tyre when it swings back it goes too far.
This could pull the bolts or bolt out of the wing as happened mine.
I had to secure it with a rubber strap to restrict it.
Its a pain if you use your boot a lot for putting in stuff.
I took mine off and now just have a few holes where the bolts were but
great piece of mind.
cheers
john 92HDJ 80 1HDT
