Walbro pumps
Craig,Gareth
thanks a lot :))))
I suspect the address is changed to :
http://www.autoperformanceengineering.com/
and there is a new model 'FRC' but none of them looks like 6065 and also no 1 micron filter?
cheers
Lubo
----- Original Message -----
To: [Email address removed]
Sent: Tuesday, December 12, 2006 9:02 PM
Subject: Re: [ELCO] Walbro pumps
Reno, Lubo,
Supplier, the best by a mile or is that a kilometre and a half for you jolly continentals, is Ron Gregory at :
http://www.autoperformanceengineering.com/html/6000_pump.html
Use the 6065 series pump in conjunction with the 1 micron filter.
Ron will despatch your pump quickly and efficiently I have used him twice and have had no problems at all. Your wasting your time trying to find one in Europe, Ron will have one to your door by the time you find a supplier and get them up to speed.
The pump compensates for wear in the original L/C pump and supplies diesel at approx 0.75 bar to the fuel filter. The L/C pump, in common with virtually all other diesels sucks fuel from the tank and is thus under a partial vacuum, hence the hiss when you remove fuel cap. The walbro gives a consistent supply of fuel, ensures there is no air ingress and slightly alters the timing of the pump to an optimised setting.
Reno - Big or Medium Trucks - I have plenty of suggestions !!
Regards Gareth Jones - Newport S.Wales.
Checked by AVG Free Edition.
Version: 7.5.432 / Virus Database: 268.15.16/582 - Release Date: 12/11/2006 4:32 PM
Hi Lubo,
You don'y need a or want a 1 micron filter (it will block too fast) you
just want a 15-30 micron trash screen as there is a filter screen in the
tank and a filter before the injection pump.
Cheers,
Craig.
Lubomir Kolev wrote:
> Craig,Gareth
> thanks a lot :))))
> cheers
> Lubo
> From: GARETH JONES <mailto:[Email address removed]>
> To: [Email address removed] <mailto:[Email address removed]>
> Reno, Lubo,
> 12/11/2006 4:32 PM
