What is this door 'stopper', 'stay' , lock thing it talks of??
I assume mine is missing, probably rusted off.
Is it fixable? Would be nice not to be squashed in windy weather !
Hello View attachment 113710
With the door wide open, push the strap in the direction shown. It should 'clunk' gently and that's your door locked open. Look underneath the door and all should be clear. If it's not working it should be an easy fix as it's a simple system.
Nowadays they'd probably achieve the same thing with two electric motors, half a dozen sensors and a dedicated ECU You'd need an instruction manual to operate it and within ten years it'd be an uneconomical repair due to needing to be reset by a Toyota dedicated software patch that was wiped from the dealer's systems five years previously...
