Which Axle Stands
------=_NextPart_001_0032_01C782DD.86C6B060
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi all, I'm a Born again Newbie
I originally joined and posted to the forum/list at the back end of l last year re: coolant draining draining/flushing and never got time to thank or reply to those who answered my questions as my hard drive failed and I lost the emails. So thank you to those who did and my apologies for not replying.
I've got lost of questions which I hope you guys can help me with asI 'm determined to do my own servicing and upgrades this summer, as I have found to my cost over the last year, (just like so many others it seems)that no one knows much about the 80 series, including the Toyota mechanics.
So to start off:
Can anyone advise me on what axle stands I should buy for the 80. I was thinking 4 ton lift for pair and Height: a Mininimum 310mm - Max at least 430mm, but would welcome suggestions and recommendations. I'm also concerned about the jaws on some I've seen, are not open or flat enough to take the axle safely.
Also is it easy/hard/possible to remove/replace the Starter on a FZJ80 without taking the wheel off? The starter has stated to run-on slightly and I'm assuming that replacing the contacts will solve this?.
I also need new HT leads as the current ones are badly worn. Does anyone know where I can get Higher spec ones(7mm) than Milners(5mm) and others Stock. From what I've gathered it would be it's a worthwhile investment if you burn LPG.
Lastly, is it better to post questions individually, or does it not matter.
cheers
Mark O'Connor
Linlithgow, UK
1996 FZJ80 Dual Fuel
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.5730.11" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial><SPAN class=3Dpostbody><FONT size=3D2>Hi all, I'm a Born
again Newbie</FONT></SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3Dpostbody>I originally joined and posted
not replying.</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3Dpostbody></SPAN></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3Dpostbody>I've got lost of questions
which I hope you guys can help me with as</SPAN></FONT><FONT face=3DArial><SPAN
class=3Dpostbody><FONT size=3D2>I 'm determined to do my own servicing and upgrades
so many others it seems)that no one knows much about the 80 series, including  the Toyota mechanics.</FONT></SPAN></FONT></DIV>
size=3D2></FONT></SPAN></FONT> </DIV>
<DIV><FONT face=3DArial><SPAN class=3Dpostbody><FONT size=3D2>So to start off:</DIV>
<DIV></FONT></SPAN></FONT><FONT face=3DArial><SPAN class=3Dpostbody><FONT size=3D2>Can
anyone advise me on  what  axle stands I should buy for the 80. <IMG
alt=3DQuestion
src=3D"http://www.tlocuk.co.uk/forums/images/smiles/icon_question.gif" border=3D0>
replacing the contacts will solve this?.</FONT></SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3Dpostbody>I also need new HT leads as
LPG.</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3Dpostbody>Lastly, is it better to post
questions individually, or does it not matter.</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3Dpostbody>cheers</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3Dpostbody>Mark O'Connor
Linlithgow,
UK
1996 FZJ80 Dual Fuel</SPAN></FONT></DIV></BODY></HTML>
------=_NextPart_001_0032_01C782DD.86C6B060--
Hi Marko,
I use Clarke CAX 3TBC 3 Ton Axle Stands and they are good enough for
me. Avoid those marked AS10 and frankly I am not sure if the AS30/A
are any better.
Rgds,
Roman (London, UK)
'92 HDJ80
Hi Marko,
I use the 6 tonne ones from Machine Mart - cheap as chips, but do the
job admirably. I have some other older types which I will replace
with a nother set of the Machine Mart/Clarkes ones later in the summer.
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
>Hello brother!
>We the born again are pretty few and far between in GB and Yurrup.
Ceferino Lamb
Euroricain 4x4 guy for Jesus
----- Original Message ----
To: [Email address removed]
Cc: [Email address removed]
Sent: Friday, April 20, 2007 12:50:36 AM
Subject: [ELCO] Which Axle Stands
Hi all, I'm a Born again Newbie.............................
Hi Reno,
I'm just a "born again" ELCO member whose Bible is any Service Manual, CD or Online Forum that can enlighten me in the ways and inner workings of the Mighty Land Cruiser. I do know that guy Jesus though, so say hello.
Mark O'Connor
Linlithgow, UK
