Whine/screech
Morning all
I have an occasional whine that sounds like a belt whine/screech. Belts are
relatively new, tension checked recently and redone, the screech is worse
when the engine is cold... So just wondering if this could be anything else
like water pump, tension pulley etc.
I=B9ve just done a thorough check and tension again but just wondered if this
was the sign of a big thing to come...
Jeremy
HDJ81, no engine mods other than addditional a/t oil cooler =AD other mods
include most of the usual suspects...
Whine/screechHi Jeremy
I used to have the same whine on the camry I had and was told to spray a little wd40 on the belt. Just a little and the reason was that the belts whine when they get too dry. But I would think if you put too much on the belt will go flying.
cheers
john 92HDJ 80 1HDT
Jeremy,
After starting the engine spray the belts with WD40 and see if it
happens again to eliminate one cause. Maybe it's worth removing the
belts to check if the pulleys are OK and if the alternator rotates
freely.
Rgds,
Roman (London, UK)
'92 HDJ80
On 3/29/06, Jeremy Llewellyn-Jones <[Email address removed]> wrote:
are
se
his
ds
I get the occasionally belt squeal in the first mile or so on a cold wet
morning when water splashes on the alternator belts - not unreasonable
when it is recharging the batteries following powering that pre-heater
screen. But not otherwise.
Do you have a pre-heater screen? And, if so, how are your batteries?
Christopher Bell
________________________________
[mailto:[Email address removed]] On Behalf Of Jeremy
Llewellyn-Jones
Sent: 29 March 2006 10:55
To: [Email address removed]
Subject: [ELCO] Whine/screech
=09
=09
Morning all
=09
whine/screech. Belts are relatively new, tension checked recently and
redone, the screech is worse when the engine is cold... So just
wondering if this could be anything else like water pump, tension pulley
etc.
=09
I've just done a thorough check and tension again but just
wondered if this was the sign of a big thing to come...
=09
Jeremy
=09
HDJ81, no engine mods other than addditional a/t oil cooler -
other mods include most of the usual suspects...
Have you tried wobbling the water pump shaft the fan sits on? Shouldn't
be any movement at all, if there is then could possibly be the water
pump bearing.
Jon.
-----Original Message-----
On Behalf Of Jeremy Llewellyn-Jones
Morning all
are relatively new, tension checked recently and redone, the screech is
worse when the engine is cold... So just wondering if this could be
anything else like water pump, tension pulley etc.
I've just done a thorough check and tension again but just wondered if
Jeremy
HDJ81, no engine mods other than addditional a/t oil cooler - other mods
Thanks for the replies everyone.
I=B9ll check it through on Saturday. Batteries are about a year old, Optima
gel batteries. I=B9ll check the water pump bearing and use a bit of the old
WD40 and see what happens. Now that it is getting warmer it feels easier to
spend a day on the car...
Jeremy
On 29/3/06 11:05, "Jon Wildsmith" <[Email address removed]> wrote:
> Have you tried wobbling the water pump shaft the fan sits on? Shouldn't be any
> movement at all, if there is then could possibly be the water pump bearing.
> Jon.
Jeremy,
It's the alternator belt, it often happens when it's cold and
it's nothing to worry about.
Regards, Clive.
It does mean that the belt is too loose though and should be correctly
adjusted.
Constant slipping of the belt causes premature wear to both the belt and
the pulleys.
Pete
Clive Marks wrote:
