Whining noise from transfer gear case
Klasagasa
sweden
Hi everyone,
New to this forum because I look for some professional advice concerning a whining/grinding noise from the transfer gear case, I think...
It starts after approx 15 min of driving. It is heard when turning the drive shaft both front and rear. As you can hear in the last two videos. The first video is shot during normal driving and the sound is clearly heard!
do you guys have any suggestion what it might be?
Oil was changed a couple of days ago because I hoped that would be the cheapest fix.
there are no visible leaks.
The car is a LC 150 2013 3.0D-4D automatic transmission.
Regards, Klas from Sweden
Crispin
Administrator
Staff member
Does it happen with the centre diff locked and unlocked?
Klasagasa
sweden
I haven´t tried it in L4 or centre diff.
it sounds as if it is a bearing gone bad. Metal to metal grinding noise!
it was on jacks when I turned the wheels to try to sort out where it came from.
having some trouble uploading the videos...
Klasagasa
sweden
First video
Moderator: Have you tried simply dragging the video from your PC onto the thread?
Klasagasa
sweden
I’m on my iphone writing... it says my type of video file does not work...
Crispin
Administrator
Staff member
There is actually a problem with uploading large files directly from the phone. I will look into it.
Best option for now is to stick them on youtube and share from there.
If you can hear it when turning the wheel by hand then it might be quite bad as there is no load at that point.
If you're handy with a spanner, perhaps take off the prop shaft to try isolate it. Remember to mark the mating point of the flange before.
Super Moderator
europe
All sounds a bit dry.
Klasagasa
sweden
Yeah, I know... but there was oil in it (1,8 L) and I changed it a couple of days ago! I only filled it with 1,6 L because the specs said 1,4 L...
Crispin
Administrator
Staff member
But not gears though. Doesn't sound like the case is empty, dry seal or something else rubbing on the propshaft.
Does it change tone if you go into low or lock the diff?
Klasagasa
sweden
I’m back home tomorrow! Will get back to you when I can check that!
Have anyone else of you heard this noise before?
It has been like this since mid october and is getting worse.
Super Moderator
europe
I've not. I did wonder if it might be the companion flange rubbing. It sounds quite a high light note.
Gasmanjc
australia
Doesn't sound like gears. Maybe dry/worn bearing maybe? Does the sound occur when in neutral at all?
Klasagasa
sweden
My guess is bearing aswell. As soon as I spin the wheels in neutral the sound starts at a low frequency. Also when driving in both drive and shifting to neutral.
Klasagasa
sweden
I started with driving in L4 with and without the centre diff and the noise is there still.
I have now torn apart the two shafts and listened to the whining noise with a stethoscope and I can hear it clearer near the gearbox and transfer case joins up on the top side.
I cannot pinpoint it further than that without tearing down the transfer case.
worst case could perhaps be the gearbox?
I am very confused right now.
Any suggestions?
Crispin
Administrator
Staff member
Sounds like it needs to go to a garage for a proper look :(
