I am in the throes of designing my front bumper & winch...
So far, I have inverted the 'hydrofoil' bumper to give me a flat surface which is level with the bottom of the chassis rails - the hydrofoil is now serving as an excellent steering guard by the way so watch this space Les!!!
With the winch on the plate, there's a lot of space above it so I have added some 45mm wooden packers to lift it (as a mock up!!!) & there's still another inch above the winch.
Hence my question - is it best to position the winch high, low or somewhere in between??
For the design of the bumper, I plan to make sleeves to slide over the chassis rails which will pick up all nine fixing points. The winch plate will the be welded between these two sleeves with bit of 'gussetry' to suit & then make a box to encapsulate the winch.
Anyhoo, hope someone can assist in how thick my wooden packers should be
