Re: window tinting -very easy
Hi Guys!
Window tinting... easy as pie!
The fastest and easiest way to pop it on the screen/window... is the same way you fit body line stickers.
Take a clean/new plastic bucket, fill half way with clean fresh water, add a tad of Fairy liquid, stir lightly, I mean lightly guys... (don't want a foam bucket).
and you are about ready. Provide a clean cloth, soft sponge and a soft line plastic or better rubber scraper (as you would use for wall paper hanging).
And bobs your uncle you are ready to roll. Cut your tint approximately an inch or so larger than the window you would like to cover. Make sure your window is
sparkling clean, dip the sponge in the bucket, wet the window and the tint, place the tint on the window and
gently stroke the tint starting from the middle working towards up and down and then from side to side with your scraper. The soapy water enables you to move/shift the tint if needed.
When all is in place and there's no little air bubbles left you may wipe it all off with your clean cloth. If you want to prevent shrinkage at a later stage it is recommended on some tints
to lightly warm it up and then give it a good rub down before trimming the edges. (the wife's hairdryer will do just fine). don't overheat for bubbles may occur.
Have done many over the years and found this the easiest and cheapest way to do... for £15 worth the try... would not pay £200 for labour!!
Have fun
African Drifter
