Michael Clark
- Jul 10, 2018
HDJ80 1997
Ok I did the 12v starter conversion. Jumped the timer relay plug. Starter relay clicks but no voltage to the starter solenoid on the starter motor.
So Im trying to trace the starter solenoid wire back to the relay. Am I correct in thinking the black/red wire to the starter motor should have continuity with the black/red wire coming from the starter relay? Or is there something in between
I do have a Toyota dealer fit alarm which could be interfering with it but want to be sure its that before trying anything else.
Is there anything Ive missed? There are two ring terminal wires no not connected to the 24V starter relay which I removed but pretty sure that has nothing to do with it.
Please help!
mike
Please help!
mike
