Andrew Prince
- Feb 23, 2010
I fitted the lifted suspension to my 80 quite a while back and did not bother with caster correction or the LSPV adjustment. The truck drives fine so I thought I'd leave it for a while and see how it went. Well my brake warning light came on on the dash causing me to scratch my head a bit - anyway Rob correctly diagnosed that it was low brake fluid level. My take on why the brake fluid got low was that my front pads had worn quite significantly - after very minimal wear in the previous 8k-odd miles that I've driven the 80 and a lot of wear in the last 2k miles since fitting the lift, I believe that it's excessive brake bias towards the front due to incorrect LSPV set-up
So I decided that it's time for an LSPV re-adjustment The LSPV set-up has the valve etc mounted on the cross-member just ahead of the left (n/s) rear wheel and the rod/lever connected to a bracket on the rear diff-casing. There are different options to re-adjusting the overall set-up. I did some research on MUD and the general view is that the easiest adjustment for a modest lift of around 2-2.5" is to move the LSPV itself. Someone did the calcs and a 2.5" lift apparently needs the LSPV to moved downwards by a 1/4". Reading through the calcs, I see that the theoretical adjustment is in fact 4.8mm which the Americans have converted to 1/4"
Anyway, I figured that I would aim for a 5mm downward adjustment (working in tenths of a mm is pretty much impossible in the gloomy wheelarch with encrusted mud and Lincomb bank vault liner ).
The plan of attack is to brush the crud off the LSPV, particularly on the 2 bolt and the slots in the bracket that the LSPV sits on. Once you've gently removed the bulk of the muck (gently because you have fairly delicate brake lines there), mark the current position of the LSPV. I just marked the very top of the LSPV by scratching a mark with a screwdriver.
Here is a pic copied from MUD with marks drawn on. You can see the 2 nuts to be loosened clearly in the middle of the LSPV body.
Once the nuts have been loosened, I gave the bolt-ends a few judicious taps with a brass hammer - obviously be careful not to destroy brake lines and unions I used a long screwdriver as a lever on the top of the LSPV to level it downwards. Because of the accumulated muck, it moves fairly slowly, so it's easy to slide it down gradually until you have it in the desired position
Tighten the nuts and the job's done! Find a loose surface with ABS disabled and test to see that you have the balance roughly correct. The fronts should still lock just before the rears.
Hope that helpful for anyone else that hasn't adjusted their LSPV yet! It's a very straight-forward job - removing the left rear wheel (not essential but makes access much easier) and loosening the 2 nuts on the LSPV are the sum total of "mechanics" involved
Cheers,
Cheers,
