- Feb 24, 2010
Today was the first time the aircon was needed since last summer, but it did very little to lower the temperature
So I tried the fridge freezer between the seats (JDM import model) and it did go cooler but not the normal freezing cold temp.
Got back home and had a look under the bonnet. The pump is kicking in and the revs are lifting slightly as normal so, it looks like a system recharge might be needed.
Am I right in thinking that being a 92 model it doesn't use the normal R34 gas... if so I guess Mr QuickFit will not be able to do the job?
