Paul
Well after picking up all the bits from Ian i decided to get some more work done on the Cruiser.
Cooling fan viscous coupling now changed, transfer seal done (and retimed the propshafts!, also seems to change gear better now too ) but when doing it i noticed that the air con idler pulley was absolutley knackered so out of interest i called the stealer and they want £91.25 + VAT for it
Will persure other avenues like a new one from Ian but i know lots of you have stripped off the air con so might have one lying around
Will give this a go with getting a grease nipple into it as it sits right on top of the engine so easy to get at.
On another note, i was washing more of the Plain out of the engine bay and noticed that the old viscous coupling spring could quite easily get blocked up with dirt, might be worth paying attention to when cleaning after off roading.
