Just in case anyone is interested, I have cut an old sphere up to show the bits inside, as said before, there is nothing magic, just a diaphragm.
First pics shoe the sphere as it would be off the car, ie the diaphragm is pressed hard against the wall of the sphere bottem.
The disc at the bottem of the diaphragm is an anti extrusion button, if this was not there, the diaphragm would simply pop into the sphere neck and burst.
If you look carefully at the black rubber diaphragm, you will also be able to see the edge of the clear plastic sheet, this along with rubber on top and below, makes up the multi layer diaphragm.
Second 2 pics show the diaphragm up against the top of the sphere.
When the sphere is in use the diaphragm will be sat around the middle of the sphere with compressed nitrogen on the top of the diaphragm and the AHC fluid below, your suspension movement is determined by the diaphragm moving up and down inside the sphere, compressing the nitrogen and thus the nitrogen acting as a spring to push it back down again.
Regards.
Martin.
Regards.
Martin.
