2 Inch Body lift
mclellan77
australia
Hi everyone in 60 land
has anyone done a 2 inch body lift on their 60 series & what is involved in doing it
any info would be great
cheers :cool:
When I did a body off restoration to my 60. I made and fitted a 65mm body lift..
What i remember as it was a while ago..
Have to drop the radiator
Straighten the hi low range lever
Extend the clutch flexi pipe
The brake lines are like metal springs so you can stretch them to compensate
Front and rear bumpers need moving up.. easy on the front but a bit harder on the rear.
Hand brake cable becomes a bit tight.
Have to check most Wires and piping arent tight under the bonnet.
Was worthy of doing, managed to get 33" s on with no rubbing. . All the best with it!:thumbup:
