Air con help
Luis 80
portugal
Hi all,
Looking for some help, have a 80, 1hdft manual, use it to travel to Portugal with the family and we do want working AC, it was retrofit as my model is the GS worked for one trip and never again, brother fitted, but immediately accept we would like a AC working in that trip. Several hours with window open is no fun. I have fitted new dryer oem, new seals, and ac radiator nissens, when it was retrofit.
What is not working, ac compressor is gone, ordered a new one, Denso, local ac guy diagnosed also 2 pipes leaking, it's like the pipes are porous, guy send me videos of that.
I wanted new pipes, Pipes are 2,one coming off the bulkhead and one connecting to the dryer.
Both partssouq no available, and anamaya say they have and then say no stock.
Didn't want pipes from UK cars as I believe the pipes as they are few years now and will possibly have the same problem I have.
What have people done when needed to replace pipes, any recommend proper specialist for ac on older cars to make new pipes. Struggle to get anyone to work on these properly.
Im in the wirral, but willing to travel for the right a specialist.
And no option to sell the 80, but did look at 150s
Order from Nayab is possibly an option, before I do so, just wanted to ask anyone had the same challenges.
Many thanks
Luis
Hi Luis,
I had same issue. The aluminium ac pipe had become porous. I sent my pipe to these guys and they repaired it. I asked for the porous section to be cut out and replaced with flexible hose to make refitting easier. If needed they can replace the entire pipe with hose, just using the pipe ends.
Thank you, that was one of the options I was looking for, ac guy I went when I asked can it be repaired he said no. Thanks
