All of the dash lights have come on my HDJ79R
ajb
Hi,
All of the dash lights are lit up on my HDJ79R and the alternator dosent seem to be charging. I wave warning lights on for battery, air cleaner, dual filter, brakes, oil level and timing belt.
I quickly checked the fuses, but they seem to be OK. I will double check tommorow.
Has anyone had the same problem? I'm thinking that a wire is broken somewhere or I have a bad earth.
Any suggestions as to where to look would be great!
Thanks,
Andrew
Check the plug on the back of alternator, give it a squirt of WD, it's a common problem, that might solve it.
I had same problem and I removed alternator and found brushes were worn out? U should be able to just get replacement brushes
if not charging and all lights are on then that's what I'd do
