Bleeding fuel system
david2001
zimbabwe
I changed my tank cradle (thanks to B Murphy generosity! ) and also the tank itself! Now after cleaning inlet mani and ports and changing the fuel filter Im ready to bleed the system to start the engine.
Can anyone pliz give detail of procedure I should follow….I have put 50 litres of diesel in the tank,fitted the new filter!No leaks so far!!!
I know there is air all along the line from tank to the combustion chambers as I also did a good inlet mani clean up..and all lines were cleaned!
All advice gratefully received!!
David
