diggerdave
- Oct 5, 2014
So, I had a weekend free last weekend and the weather was ok so I carried out some jobs. I fixed my intermittent reverse light (new gearbox switch for £9-99 from Ebay), engine oil and filter (4500 miles since the last one... I left it a bit long!) and a new fuel filter.
BUT the most important job was to fit my new CB radio before my next laning trip. This is a Thunderpole T-1000. Its a very basic set, which hopefully makes it suitable for a noob like me who doesn't know much about CBs. My usual laning partner has bought the same in the hope that we can troubleshoot together if need be!:
Having spent a bit of time trial fitting the set, there was only one logical place for it to go in the LC90 and that was in front of the gearsticks. There is a slight 'tray' shape moulded into the trim right in front of the levers that would be ideal. In my case a previous owner had mounted a 'mystery object' there leaving me with two existing screw holes:
The trouble is that the 'tray' is actually a bit awkward. I really wanted to be able to tilt the CB upwards so that the display and controls pointed upwards. That required removing the 'pocket' type trim that lies below the ashtray, to allow the rear of the CB radio to tilt down...
...and making a raised 'shelf'' out of a block of scrap wood. I covered it with old car seat material using a staple gun - it's mostly hidden so it doesn't need to be a perfectly finished job! (any material or paint would do but I like the car seat material as it gives it more of a factory look, at a casual glance anyway). Here's the wooden block screwed into position from underneath the gearstick trim, with the CB radio mount screwed into the wooden block in turn. It looks a bit ugly in front of the gearstick trim with the 'pocket' trim removed, but all that will be hidden by the CB radio:
I decided to hardwire the CB radio into the battery as this is recommended on some forums to minimise the chance of electrical interference. I don't know if that's an old wives tale, but I'd rather have my two 12v lighter sockets free anyway and it wasn't hard to do. I ran the positive and negative wires above the pedals (later cable tying them up out of the way) and out through the rubber boot in the bulkhead that is just above and to the right of the accelerator pedal and into the engine bay (it's the black and red wires):
Getting the wires through the rubber boot is a bit of a fiddle. I daresay a bit of bent coathanger wire would help, but luckily I had a handy pair of... er... thingies
I have no idea what they're called, but you get the idea. When you squeeze them together they lock in position, gripping the wire:
Then it was a quick trip to Halfrauds to pay an eye-watering price for a couple of yellow ring terminals (8mm holes), which I just crimped on to the ends of the wires (there will be letters! Yes I know soldering is better but I'm really, really crap at it and it's only a CB radio). The power wire is supplied with a fused link, so no need to worry about that. The positive terminal screwed onto the positive clamp, and the negative terminal screwed onto the bodywork as an earth, visible screwed onto the inner wing behind the fusebox (spot the two yellow ring terminals):
BTW I don't know much about vehicle electrics although this seems a simple job. If I have done anything stoopid there, please let me know (nicely!).
And that's it... one CB radio installed. Of course, it's only half the job. Installing the aerial and checking the SWR is a separate job that I'll add soon once I get the chance to take a finished picture of the aerial in the light, but for now here's the CB radio in position:
