central diff lock in high gear (HDJ80-24V)
Hi,
does anybody know how the modification regarding locking the central
differential in high gear can be done - I'm quite sure it can be done
since when you put in low it is automatically turned on (and ABS off) -
so the wires should be there ...
Thanks in advance for your help.
Best regards,
Tomaz
Julian Voelcker wrote:
Jup I have done it on my 80, and it works like a charm :) ... the switch
i a bit expensive but.. worth it in my opinion..
Michael Thorsager, Denmark, http://gallery.vx80.dk
1997 VX80, 2.5" OME (and some other stuff)
Hi Michael,
If you are lucky you can find them on Rav 4s - just need to find a
scrapped one!
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift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Guys
Is centre diff in high gear a good idea?
If it was surely it would be standard capability.
More liable to break something bombing down the track with the CD
engaged in high gear?
Niall
Hi Niall,
I think it is ... but of course on the rough tracks or sand - definitely
not on highway.
On KZJ95 (prado, colorado) there is in addition to H and L also HL which
uses higher gears then L but with central diff locked and it is
recommended (in the car manual) for off-road etc...
regards,
Tomaz
Alright Tomas
Had my HDJ80-24V in Morocco - lots of dune driving, stoney desert and
deep sand tracks. Was loaded heavy as my buddies Landrover calved in
Spain and they jumped on board the Cruiser.
Didn't have to engage any diffs at any stage - just cruised along no
bother.
I rekon once you're at high range speed the requirement for diffs being
engaged is minimal - in most cases - but i'm no expert.
Also - would it not impeed ability to steer the vehicle around
corners?
Niall
Hi Niall,
since I just recently switched to hdj80 all my experiences are based on
kzj95 and in that case the HL with central diff locked was very useful -
tho control of the car off-road was better - but hdj80 is a different
animal ... the gears are different and maybe it is not that useful.
regarding the corners - you are right but still drivable ...
Tomaz
on
There's an interesting entry on the 80s-cool technical pages which says
that if you:
- engage the CDL, which automatically switches off ABS
- then exceed 70kph for at least 200m
The ABS stays switched off until you turn off the ignition and restart
the engine. The thinking is that on loose surfaces and snow you are
better off without ABS, and this is a good way of disabling it.
See http://www.lcool.org/technical/80_series/abs.html
No, I haven't tried it! I installed a diff-lock switch so that I could
turn if off when in low range - dead useful for towing and reversing on
tarmac - not turn it on in high.
Christopher Bell
Devon, UK
1996 1HD-FT
RE > The thinking is that on loose surfaces and snow you are
Stopping distances on gravel with ABS engaged is far greater than with
it dis-engaged. I've experienced this on a defensive driving coures in
Australia.
Niall
Has anyone ever looked in to the possibility of putting in a switch to
dis-able ABS?
Clive Marks
Home: +44 1293 514600
Mobile: +44 7821 491897
Crawley, West Sussex, UK.
Oh hello the Clive this is so easy for any body to do. Any capteur on
the road wheel can have it's wire put with a switch on it. Voila press
the switch and she ABS is in default.
Niall
| Australia.
I've experienced it on bumpy "tarmac" roads in Devon! If the wheel is
airborne the ABS gets kittens and you don't stop.
99% of the time I'd rather not have ABS, trouble is the other 1% it
might save your bacon.
Hi Niall,
I have used it occasionaly when driving across muddy fields and I have
started to slow and I also engage it when very icey/snowy - it just
helps keep you in a straight line.
I also used it a couple of times in the dunes in Morocco, although once
I had lowered the tyre pressures it wasn't required.
Benoit
| Please what does that mean?
"Having kittens" (=3D giving birth to baby cats) is yet another English
expression. It means getting very excited and/or upset about something.
At the time I was driving down a steep hill on a narrow "road" near
here, and someone was coming the other way, so I wanted to slow down and
pull in to the left.
However the road was so rough that my left wheels were bouncing up and
down, and when they were in the air the brakes stopped them turning. So
the ABS thought "the left side of the car is skidding" and starting
doing its butt-cheeks thing.
So we just kept on rolling downhill with the ABS farting away, taking
about an extra 50 metres to stop. I was not happy!
Christopher Bell
Chris, I though by now we would have a butt cheek analogy ready. No perhaps
we don't want one linked to ABS and stopping.
Malcolm Bagley
Stafford UK
FJ45 '75 & FJ45 '76
Checked by AVG Free Edition.
Version: 7.5.484 / Virus Database: 269.12.2/967 - Release Date: 22/08/2007
18:51
Malcolm
perhaps
| Malcolm Bagley
I thought butt cheeks and the noise made by ABS made quite a good
association, but I'm happy to defer to your linguistic and/or mechanical
preference...
CB
