MisterCruiser
- May 28, 2014
Ok, so this is an issue with my 90 Colorado 3.0 1KZ-TE model.
I've had an issue with the battery going dead, checked the voltage with the vehicle running and was over 14v so I thought the alternator is working ok. So I blamed the battery and bought a new battery. This vehicle doesn't get used a lot so I thought in the freezing cold weather the battery was just old (it's 4/5 yrs old) and that it's struggling to hold charge in the freezing weather. I charged the battery etc, etc,, prior and still discharged.
Anyway, new battery seemed to cure everything. It's in it about a month. Until yesterday evening, I went to move the vehicle out of the way and the battery was flat as a pancake.
Strangely, after I jump started the vehicle yesterday, when I checked the battery voltage with engine running it was reading 12.9v, it wasn't up at the 14v you'd expect,,, could this be because the battery was so flat that the alternator was charging correctly and as the battery became more charged it would eventually read at 14v or should a completely flat battery still charge at 14v right from the start?
I had the battery charging whilst it was connected in the vehicle, (my CTEK charger allows this) and I was working on another car parked beside it when I started to hear clicking noises coming from the cruiser. I pulled the "SUB GLW RLY" relay and the clicking stopped, which I assume is the glow plug relay.
There was also another part clicking up at the top of the engine which when I disconnected the electrical connector the clicking stopped, I'm not sure what this connector is, if someone can identify the green circled connector in my pic that would be great!
Also, the seatbelt warning or SRS? red circle with seatbelt pic was flashing on/off on the dash, this was the only thing flashing on the dash.
So I think this means I have a short somewhere which in the form of a live wire touching some chassis or such?
Also, I think I "broke" the main Alternator fuse link in the pic below. Are these designed to be removed to check or how do these work? How do I remove the old one? Can these only be got from Toyota, I never see these type in motor factors, etc...?
If I go to a breakers, how do I remove that main Alternator fuse from the fuse box without breaking it?
I need to get that main alternator fuse link as at present, I get absolutely nothing when I turn the key, I assume because the main Alternator fuse link is broken?
Also, to check for a parasitic drain, I put a test light between the neg battery post and it's disconnected cable clamp and it glowed very dimly, I pulled every fuse in engine bay and interior and the light stayed on. I put my multimeter on amps in place of the test light and couldn't get a reading on either of the 3 amp settings so I assume it's miniscule amount and hence wouldn't read it?
