Aussie Nobby
- Dec 4, 2015
I have a 100 series Standard Landcruiser built April 1999. The air conditioner is run a least once a month. Recently when the air conditioner has been turned on the engine does not idle down. The air coming out of the vent is so cold that at times a fine mist can be seen. The compressor is also very hot to touch, however I have read that this is normal. The compressor is running quietly. Can you advise how to fix the idle control and should I be concerned how hot the compressor is running?
