Engine swap
Smurt2010
australia
Hi just checking if anyone on here could give me some information on a engine swap in a 1999 1fz-fe
i have automatic transmission and second hand motor received is out of a1999 1fz-fe manual where the flywheel mounts are different on the two engines is there an adapter for manual flywheel mount to allow auto flywheel and torque converter to fit first one is manual engine second is original automatic engine
The crankshaft and engine block will be the same on both engines so it should all swap over...
The boss in the second picture looks like it should come off the end of the crank....you may have to remove the spigot bearing in the manual crank to get it to fit that engine .
