Rework the coords as degrees minutes and seconds and it should work. Also some like the S or The E at the end instead of the beginning. can't remember which G Earth is.
I put those coordinates (used copy and paste) in Google Earth installed on my laptop and it took me to a flyover on the N3 just outside Bruntville in South Africa. The sat image is pretty clear and detailed - you can easiy see the vehicles on the road. Also looks like it is close to a toll booth??
I have never really compared. I tend to use Google Earth because you can load .gpx files which contain gps waypoints to show your track over the satellite image. Not sure you could do that on Google Maps.
Warren, the S coordinate is approx 29.222 degrees. 0.2222 x 60' is roughly 13' so the coord is 29deg13mins10seconds South. If you look on Earth it does show that. Sometimes the coord data needs to be entered in this format in devices and apps
