Matt Wright
Hi all
My 80 series has had a rough time with radios in the past it seems. The factory fitted ISO connectors are all but cut off and the last radio that was in there was wired up (somehow?!) to a strip connector.
The tricky part is that the wires coming out of the loom are very short and don't move even half way through the space where the radio goes so tracing them is hard - crimping them back to a new ISO connector with wires is even tougher.
I was wondering if anyone else had been through this same issue before and had any hints. I've researched the Toyota manual and it wasn't that helpful [elthough I may have not understood it?!]. Also tried various websites but they all speak of more perfect, simpler scenarios ie a +, -, ignition on the one ISO connector and the speakers on the other..
I am trying to fit a radio that has the "standard" connector set. It's the most common one found online, follows the international std's - and it's what Halfords sell! It fits my radio perfectly so if I can connect it to the wires correctly, it'll be a cinch to fit!
What I have researched says the Toyota wiring loom wiring legend is
- Does this look correct? The wires in my loom look different........
P o w e r
Memory (+12v Constant) Blue/Yellow
Ignition (+12v Switched) Gray
Ground (-) Brown
Illumination Green
Dimmer White/Green
Power Antenna Black/Red
S p e a k e r s
Right Front (+) Light Green
Right Front (-) Blue
Left Front (+) Pink
Left Front (-) Violet
Right Rear (+) Red
Right Rear (-) White
Left Rear (+) Black
Left Rear (-) Yellow
The ISO connectors are :
Green, White, Grey and Purple for the 4 speakers, each has a counterpart that has a stripe.
Bought from Halfords.
http://www.halfords.com/webapp/wcs/..._productId_180394_langId_-1_categoryId_165626
What I have :
http://www.africaaboveandbelow.com/ELCO/radio/iso1.jpg
http://www.africaaboveandbelow.com/ELCO/radio/iso2.jpg
What my dash looks like
Photo 1 shows the wires literally crimped right after they exit the loom
http://www.africaaboveandbelow.com/ELCO ... wires1.jpg
Photo 2 shows the ISO blocks almost all cut off and the bigger picture / mess
http://www.africaaboveandbelow.com/ELCO ... wires2.jpg
The way suggested to test (apart from plugging the radio in is):
To check hot, ignition, lights, dimmer, use a test light or voltmeter
To check speakers use test radio
To check speaker polarity (assuming you don't have a polarity tester): Touch (for a very short period of time) one wire to the positive side of a 1.5-volt battery (any size), and the other wire to the negative side. If speaker "pops out", then polarity is correct. If speaker "pops in" then polarity is reversed. Make sure that the wires you are going to check for speakers do not have any power.
So, in summary :
Has anyone done something very similar to this before (short hard ot get to wires)
And anyone know if the colours above are correct / what the correct ones should be?
And finally, what the mapping should be?
Thanks! (driving me nuts!
P o w e r
Ground (-) Brown
Illumination Green
Dimmer White/Green
S p e a k e r s
Left Front (+) Pink
Right Rear (+) Red
Left Rear (+) Black
What I have :
So, in summary :
