I don't think it got very good reviews...
This looks like a translated excerpt from the a Chinese Auto Review.
"Compare the driving characteristics Fuqi with habits "vosmidesyatki" - at least not correctly. In "Chinese" apparent mass of punctures. For example,
vague steering does not give confidence in the fact that you are completely in control of the car at medium and high speeds.
In the city maneuvers are complicated by the low sensitivity (wheel at transpositions need to rotate through large angles).
Almost complete absence of the stabilizing moment: at the exit of the sharp turn the front wheels do not seek their own return to "zero" position, forcing the driver hard to turn the wheel and to constantly monitor the position of the wheels.
Also, the Chinese heavy steering wheel, pedals tight, pretty stiff suspension that vytryasyvaet whole soul.
Mechanical five-speed requires experienced hands switching mechanism is different definition of work, and the course of the lever is so great that the central second transmission lever hits the plastic frame of the tunnel. "
None of the parts are interchangeable with Toyota, so you are restricted to the Chinese parts stocks and supply chain, which is unreliable.
