[LCML] Spark plug tire inflator
Anyone ever used on of these. Seem to be an Australian thing, when I was a
kid our FJ40 came with one, don't remember us ever using it.
Seem a little strange to pump a petrol / air mix into you tires (tyres),
wouldn't it cause the tube to perish?
http://cgi.ebay.com.au/1960s-air-pump-tyre-inflator-unused-Use-or-display_W0
QQitemZ130119212887QQcmdZViewItem
http://tinyurl.com/2sn3wq
Malcolm Bagley
Stafford UK
FJ45 '75 & FJ45 '76
Checked by AVG Free Edition.
Version: 7.5.472 / Virus Database: 269.8.9/832 - Release Date: 04/06/2007
18:43
LCML Homepage/Unsubscribe: http://www.birfield.com/mailman/listinfo/landcruisers
Host Website: www.birfield.com
LCML under-written in part by the Toyota Land Cruiser Association (www.tlca.org)
Hi Malcolm,
If you read the blurb, the device lets the air be sucked through it rather
than from the inlet manifold, this would reduce the ammount of fuel
mixture although I guess you would get some.
An interesting contraption none the less!
Mobile: 07971 540362
Skype: julianvoelcker
1994 HDJ80, 2.5" OME Lift
Could the compression have operated a pump so no mixture from the cylinder
was pumped through?
TTFN
Chas
London UK 1HDT 80 Safari snorkel, Custom Winch bumper and Rear bumper with
spare wheel carrier.
----- Original Message -----
To: <[Email address removed]>
Sent: Wednesday, June 06, 2007 10:00 AM
Subject: Re: [ELCO] [LCML] Spark plug tire inflator
Hi Julian,
I cross posted onto a US list, seems they are also available in the US.
Contention is the unit incorporates an diaphragm air pump and uses cylinder
compression air to pump clean air into the tyre.
Sorry not much use for you diesel guys.
Malcolm Bagley
Stafford UK
FJ45 '75 & FJ45 '76
-----Original Message-----
Behalf Of Julian Voelcker
Sent: 06 June 2007 10:01
To: [Email address removed]
Hi Malcolm,
Version: 7.5.472 / Virus Database: 269.8.9/834 - Release Date: 05/06/2007
14:38
14:38
