Hi All,
I installed my awning on my 80 Series a few weeks ago and have decided to put an LED strip along the inner frame of the awning behind where the canopy rolls out. I did a similar job on my old NL Pajero but this time I've decided to do things a bit differently.
I've only recently purchased my 1994 80 Series GXL 4.5 and with very few after market components so i'll be putting some effort into doing a tidy job on the electrics.
Firstly, I've purchased a small fuse box that I'll be powering from my auxiliary battery and fitting underneath my console (running power through firewall as auxiliary battery located in front). Have a 10A fuse in at the moment but I may reduce this when I measure the draw after installed.
I've also invested in a number of rocker switches and switch trays for a tidy job. It's on-off with 2 LED's and and 4 poles for wiring. See diagram:
So, before I go installing the LED strip I wanted to ensure I fully understood the switch wiring and explored ways of minimizing amount of cable required when wiring many switches in the same tray coming from the same power source, but controlling other accessories.
I've used 2x 6V batteries in series for a 12v power source and some single core 10A cable with alligator clips either end to build my DC circuit.
OFF: (You can see one LED on switch is correctly lit, LED strip is NOT lit)
ON: (Both switch LED's correctly lit, LED strip also lit)
ON: (Reverse angle, best for looking at the actual wiring of the circuit.)
One observation i've made is wiring pole 2 and pole 8 together from the power source rather than running individual cables will save a lot of hassle and cabling.
Anyways, proof of concept completed. Waiting for a dimmer and additional components before installing.
FYI I am not an expert and have learned from many sources
. Make sure your fuse box/circuit is using adequate cable to handle the load you intend to draw. Do the maths before wiring anything up and do additional research if you're not comfortable.
Hope this helps!
Will
Hope this helps!
Will
