Hi All,
Gmac here. I just joined. Hope I can find an answer to how to test my sub tank sender unit is operating properly. I recently put a long range tank in and all was working well until recently when the low fuel light came on.
I suspect it is this sender that may be the issue & the float is full of fuel & sitting on the bottom of the tank. When I disconnect the sender, my main dash gauge shows a change in the amount of fuel I have so I think the gauge is working to some point. If I disconnect the plug, how can I send a signal back to the dash gauge to see if the low level light goes out?
