dadinabarrel
- Oct 26, 2013
Has anyone put an auto trans into a 1HZ HZJ75? I'm hearing about early 60 series, 80 series with major electrical difficulties, now I've come a cross a guy saying you can put a Turbo 700 in there. I need the right info before I jump.
The motor is only 60,000km old, after market turbo, upgraded rings and fuel pump, gas over the top.
While I'm at it
the boost is set at 7PSI, with the gas coming in at 2PSI. How much are you running? I've seen 10PSI bandied around quite a bit.
While I'm at it
