Manual transmission
markus67
Hi fellow forumers
so I have a KDJ120 and needed to remove the transmission, but I just couldn't slide it off the input shaft, it was that tight that I had to remove the side inspection covers to see the release fork, pressure and clutch plate, I had to undo the pressure plate to get it off the flywheel.
Has anyone else had this issue and if so could you please let me know how you did it??
Or, am I missing something such as a C-Clip or something else
Am grateful for any help you are able to provide
Regards Mark
