- Feb 24, 2010
Folks,
My time has come.
Last night on the way home I was slowly accelerating away from an intersection (behind a uhem, normal car
) and lost power. Pressed the pedal slightly and nudda. Started to move over to the side of the road and with a thump, it was back. It felt like you had turned the cruise control back on. No spluttering back to life, just a “Right, where were we?” and off we went. It was only for about 5 seconds.
Must say though, power loss was not a “oh crap I am slowing down” it was more a “I can cost here”
No amount of playing could reproduce it. Giving it some wellie through the gears did nothing, trying to accelerate in the wrong gear was normal (with normal turbo lag) etc etc.
This morning, on the way to work, I noticed the idle was slightly erratic. When idling with a warm engine, the needle is always dead still. This morning there was a slight “quiver” in it. Nothing big. Shortly thereafter, the same thing happened; no oomph. This time it was only a couple of seconds and not doing anything, it returned. Again, not able to repeat.
Both times, there was nothing to suggest it was about to do it. Both times I was in 3rd gear accelerating away from an intersection. Recovery was also swift with no fuss.
My first thought was the new tank of Tesco’s finest that I got on Monday. Could it be a fuelling issue? Would water or other contaminant not cause a splutter, not an on-off feel?
First time was about 50 minutes into a journey, second was about 10 minutes in.
Thoughts?
Will be off tomorrow to friendly dealer to see if he can read the codes for me. If it’s complicated then I’ll book it in.
My time has come.
Thoughts?
