nieboo
- Dec 16, 2022
Here is a case for the experts among us.
My 80 with a 1HD-FT engine recently had a gearbox, injectors and injection pump overhaul. Since then - but this might coincidental - it is losing oil from mainly the EGR valve and along the block below the air inlet side around cylinder #6. It has had low oil pressure indication for as long as I have owned it. I can feel no pressure on the cranckcase, when I take out the oil dip stick and have not noticed a big change in the oil level. There is some weeping from the PCV hose as well - both at the cam cover and the air filter sides. The engine runs smoothly though. I will post some pics below. For some reason 2 are in the wrong orientation... Sorry for that
I am trending to a turbo related issue - anyone with another idea ? Thanks for any input.
