Rear diff lock problem
Corvus
iceland
Hi everyone, the rear diff lock is not engaging on my Toyota Land Cruiser 120, any suggestions what could be the problem?
C
Hello - welcome. Unfortunately the difflock actuators are a weak spot on these. Some have successfully repaired them (there are several threads and YouTube videos dealing with this) but the aluminium housings often fall apart when trying to remove them from the axle. Has yours worked previously and not working now? Could just be wiring connections
Hi and welcome if it is a factory diff lock they are a permanent magnet motor and the magnets come loose in the motor case bugger of a job there is a thing on it in youtube but it is a diff center out job to fix or buy a new unit and fit it
