Rear Roter Replace/Simple Question
Bauerjab
I have a 2008 LC.
I am going to replace the rear rotors. I know that I will need to rotate the rotors to position the "hole" in the rotor to 6PM to get access to loosening the star gear of the e brake. I will be jacking up one wheel at a time.
My question is simple. Will I be able to rotate the wheel once that wheel has been jacked up if the car is still in park? Do I need to start the car in neutral and then turn it off? What is the best way to do this.
I have never worked on an all wheel drive car before.
Thanks!
