Reverse Camera on a 2020 LC79
anconap
australia
Can somebody please assist as I can't find any specific information.
I have a new 79 with a head unit PZQ60-00345 and I need to install a reverse camera utilising this standard head unit. I don't want a separate screen. I have the camera and basic wiring to feed up to the head unit.
Is there a specific wire harness that I need to plug into the rear of the head unit?
Any help will be great.
Peter
ye u need a adaptor..... probably go to autobarn or supercheap or something like that.... aerpro makes these aftermarket cables.....
Hi sonic. Thank you very much, you’re a legend. I found it through aerpro.
Was this issue resolved, I'm now going through the same process. Aerpro yesterday emailed me to say they do not make a harness for the VDJ79. I purchased two harnesses so far from Aerpro, a 4 pin plug which is incorrect and a 12 pin APVTY12 patch harness which is the correct plug but it does not operate the screen.
The head unit is PZQ60-00345 and it may be the same at used in 2019 200's and probably some Hilux, Subarus etc all of which have reverse cameras.
As I have the plug, I can probably wire it up to make the camera operate, I just need a wiring diagram to show where to run the cables from the APVTY12 to. Aerpro are of no assistance.
Toyota appear to offer a harness, PZQ 00230, as a patch harness for Hilux. To use that I would still need a diagram showing how to run the cables as the plug may not have a socket in the VDJ.
