CCtiger
- Sep 1, 2017
Hi guys, I had a Tiger 2 1200lb winch from my old 4x4 installed on my 70 series LC. I have used the winch about 10 times in total and that was just spooling in and out to keep things from seizing. The winch has not been submerged, or used for any recoveries. I went to use it the other day and it would not work.I swapped the cable control to the remote control same result. I thought it may have been the solenoid so I replaced it. same result. I used a small cable to "jump" across the terminals on the winch motor and used an external battery and the motor winds in and out no problems. I think it may be the actual plug at the top of the control box that may be the problem? If anyone has any suggestions it would be appreciated. Thanks.
CCtiger
CCtiger
