P ppramires New Member Joined Nov 3, 2024 Messages 2 Country Flag Nov 9, 2024 #1 hello everybody What should be the normal pressure of the Toyota D4D 3000 cm3 (diesel) turbo? thanks
Shayne Well-Known Member Guru Joined Feb 2, 2013 Messages 17,183 Nov 9, 2024 #2 D4D is a variable vane turbo so has no wastegate to set pressure , it electronically increases boost right through the rev range .
P ppramires New Member Joined Nov 3, 2024 Messages 2 Country Flag Nov 11, 2024 #3 Shayne said: D4D is a variable vane turbo so has no wastegate to set pressure , it electronically increases boost right through the rev range . Click to expand... Thank you very much for the answer. My question is wrong, what is the maximum pressure? 1.5(0.5) bar? 1.9(0.9) bar? Thanks
Shayne Well-Known Member Guru Joined Feb 2, 2013 Messages 17,183 Nov 11, 2024 #4 I wouldn't know how to begin programming a variable vane but from memory I think we learned the 1KZ-TE cuts fuel if you boost past 12psi . hang on something was posted recently that might help if i can find it
Shayne Well-Known Member Guru Joined Feb 2, 2013 Messages 17,183 Nov 11, 2024 #5 https://www.landcruiserclub.net/community/threads/toyota-prado-colarado-90-w-early-1kd-egr-blank-and-butterfly-removal.161317/
