Water in the sill
I've just drained water out of the sill on the driver's side.
Any idea where this might originate from? I remember seeing something on the
list about it but cannot find it. Is there a blocked drain hole somewhere?
HDJ81
With some stuff.
Jeremy Llewellyn-Jones
Mob: 07831 458 793
I had this a few months back.
All of a sudden one day there was this sloshing sound that for some stupid
reason I assumed was the sound of LPG sloshing about in the load-area tank.
Then I realised and removed a grommet from the nearside sill; about two
gallons of crystal clear water ran out.
I've never had this happen before or since so I'd like to know a possible
cause too.
Pete
-----Original Message-----
Behalf Of Jeremy Llewellyn-Jones
Sent: 07 May 2007 18:14
To: [Email address removed]
Subject: [ELCO] Water in the sill
HDJ81
With some stuff.
Mob: 07831 458 793
Checked by AVG Free Edition.
Version: 7.5.467 / Virus Database: 269.6.5/792 - Release Date: 06/05/2007
21:01
21:01
21:01
one of your water hole drainer plugs is blocked.
I've seen this b4 (had it happen on mine as well but can't remember where the plugs where :)
checkout 80scool or ih8mud
Lal
Peter Browning wrote:
Been searching fore the drainer plugs but cannot find them...
Jeremy
Pete, maybe someone will come up with the answer.
Mob: 07831 458 793
Jeremy
They are under the sills. I have removed them altogether.
Rgds,
Roman (London, UK)
'92 HDJ80
On 5/7/07, Jeremy Llewellyn-Jones <[Email address removed]> wrote:
Roman
I've found them - but just wondered how the water gets there in the first
place?
Something somewhere must be blocked...but then again its not that
important...
Jeremy
Mob: 07831 458 793
Just seen this on 80s cool...thought `I'd seen something sosmewhere
The problem actually is the drains in the rocker panels and it applies to
all 80s. The drain slots are very small and clog easily.
There are three on the bottom of each sill under the doors, one near the
front, one at the middle and near the back. They are right on the seam and
can be difficult to find. When you have a close look, you'll spot them. A
fine stick or something will clear them (actually, the thin end of a zip tie
is good). It is an idea to pull the rubber bungs and flush the rockers out
every now and then. They fill with dust and once water gets in, it makes
mud.
Mob: 07831 458 793
Rocker panels?? What is they???
Pete
Sent: 07 May 2007 20:11
Subject: Re: [ELCO] Water in the sill
mud.
Mob: 07831 458 793
21:01
21:01
21:01
On 7/5/07 21:16, "Peter Browning" <[Email address removed]> wrote:
Sills
Mob: 07831 458 793
Ah, OK
But then why would I get water in one sill suddenly, and a lot of it, but
never before or since? I haven't cleared any drain holes, I just took a
grommet out to drain the water and then replaced it.
Pete
Sent: 07 May 2007 20:38
Sills
Mob: 07831 458 793
21:01
21:01
21:01
Not sure I understand either. At least we know how to drain it out...
Jeremy
Mob: 07831 458 793
