Water leak
CORKY
australia
Anybody have or had a water leak a puddle on the floor on the driver's side inside running down
From some place I don't have a sunroof got to be coming from the side or some place
Most likely rust around the windscreen, particularly if you've had it changed.
Agreed, my 95 series had a leak at the top of the replacement screen where the sealant had come adrift. The headlining was wet at the front edge which was another clue.
It has been known for mounting points on factory roof rails to leak, if your's has them.
Thanks tractionman it could be that as I've tightened them up doesn't seem to be any more water coming in at the moment hope that fixed it,
