Howmanygoes
- Jan 14, 2019
As you know I am in the process of redoing my storage and kitchen and as part of this I wanted to add some gullwings to make the space more usable. I debated on which brand to go with and I saw a recommendation for wings from The Crusier Company, TCC for ease. Home | The Cruiser Company - [Leaving Land Cruiser Club]
I watched a YouTube video of the wings being fitted to an 80 and seemed to all be straight forward. I liked the clean look and they suited my budget.
I ordered a pair of wings and the initial interactions with TCC were all good. Long manufacturing lead time (6 weeks) and then covid based flight disruption and Christmas meant a long wait till the end of January.
Yippee they arrived...
So first I must say Sam at TCC is doing what he can to address the issues I have raised with them, but there are some design and instructional issues that need to be overcome. It's not a straight forward install so far.
First up warehouse picking issues.
I received 2 passenger doors and 2 sets of upper and lower strut mounts but both for the same side. Also received m6 nuts to partner all the m5 bolts. The nuts also aren't nylocs so they either need swapping out or loctite applying.
The instructions seem to have a mixture of images for different models and that might be why some of the instructions are inaccurate, eg:
If you follow this, then when you assemble the top plate, the additional metal plate and the hex head bolts foul on the body work. Which also means you now have an extra set of holes to deal with and the top left fitting actually aligns with an internal metal profile so you cant fit the nut and washer on the back. See below
When you finally get the plates and door in right place, the biggest disappointment and design floor becomes very apparent.
This is ridiculous, and there is no adjustment to be able to bring it closer in, it actually needs bending to align with the body shape. The image below is from their website, you can see a small gap but nothing the size of Jordan's gash.
So when TCC open later they will get a request to sort it all out.
Fingers crossed it can be sorted.
