bookend said:After removing the compressor I to Strip the Air Con clutch on the cruiser to see if I could fix the noisy bearing
It's a pig to remove but once off I used clothes pegs to get the clutch plate off
Once separated there is a circlip the remove then the other half comes off.
This is the bearing that's noisy
I have ordered a bearing so just need to press this one out and the new one in.
Then put it all back together.
bookend said:Just pushed the bearing out in the hydrolic log splitter
Just need the new bearing now.
