- Feb 2, 2013
Sadly i remain unconvinced , if the turbo is set to ram 14psi into the pipework intercooler or not that's exactly what it will do leak or no leak . There is no electrickery on the 1kz-te to second guess the mechanical wastegate which might be described as a blow off valve and i ask where does the back pressure come from to open the wastegate if the pipework is not filling to the set pressure ?
Sadly because if i thought 14psi at the actuator only showed 12psi at the pressure sensor i would up the boost some more .
I left my truck outside a pub yesterday but if it stops raining by the time i get it back i might experiment by connecting the gauge to the intercooler .
