Yorkshire Devil
- May 27, 2012
I'm looking at purchasing a Detroit TrueTrac Locker set For a KZj70
Can anyone help identify from the list below which locker I would need for the front I do not understand the anyone between 2 & 4 pinion?
I'm 99% sure I need the 913A610 for the rear (as this is what other forum members have used) but am really unsure on the front. How many pinion is the front locker?
Can anyone help shed light on this?
http://www.filthymotorsports.com/Detroit_Truetrac_p/eaton-truetrac.htm
Toyota Detroit Truetrac Lockers
The following models of Detroit Truetrac are available for Toyota vehicles:
Vehicle(s) | Axle | Year | Description | Spline | Ratio | PN / Link |
Tacoma, Tundra, T-100, Hilux, 4Runner, Celica | Front | 74-85 | 8" (2 Pinion) | 30 | All | 913A609 (l) |
Front | 86-88 | 7.5" IFS (4 Cyl) | 27 | All | 911A445 (l, m) | |
Front | 89-95 | 7.5" IFS (4 Cyl) | 27 | All | 911A342 (m, n) | |
Front | 86-04 | 7.5" IFS (6 Cyl 4Runner) | 27 | All | 911A445 (l) | |
Front | 86-95 | 7.5" IFS (6 Cyl) | 27 | All | 911A342 (m) | |
Front | 95-04 | 7.5" | 27 | All | 911A644 (l) | |
Rear | 80-95 | 7.5" | 27 | All | 911A565 (n) | |
Rear | 74-96 | 8" (2 Pinion, Non-Turbo) | 30 | All | 913A611 (l) | |
Rear | 86-96 | 8" (4 Pinion, 4 Cyl, 4x4) | 30 | All | 913A610 (o) | |
Rear | 86-96 | 8" (4 Pinion, 6 Cyl, 4x4) | 30 | All | 913A610 (n) | |
Rear | 86-96 | 8" (4 Pinion, 2WD Chassis Cab) | 30 | All | 913A610 (n) | |
Rear | 95-05 | 8.4" (4 Cyl Tacoma, Tundra, T-100) | 30 | 3.54 + | 913A541 | |
Rear | 95-05 | 8.4" (6 Cyl Tacoma, Tundra, T-100) | 30 | 3.54 + | 913A541 | |
Rear | 95-05 | 8.4" (4 Cyl Legend Racer Series) | 27 | All | 911A565 (n) | |
Rear | 95-05 | 8.4" (6 Cyl Legend Racer Series) | 27 | All | 911A565 | |
Land Cruiser II, FJ Cruiser | Front | 90-07 | 8" (4 Pinion) | 30 | All | 913A612 (n) |
Rear | 05-09 | 8.0" (FJ) | 30 | All | 913A610 | |
(l) Fits "small” hub bearing dia. 45 mm. (m) Will not fit selector disconnect “shift on the fly.” (n) Fits "large” hub bearing dia. 50 mm. using Toyota bearing #90368-50006. (o) 32010X bearing allows 913A610 in place of 913A611. |
