- May 20, 2010
As the heading states.I have an issue.
On my 80 I have the NS front wheel smoking. It smells very hot.
I noticed this a while ago and thought it was oil getting into the wheel bearing and making the bearing wear out.I change inner seal and fitted a new bearing and all seemed ok.
When I went down to Poole to collect another truck all was ok. On the way back home got a lot of smoke coming from the wheel again. I checked the bearings and they were ok but I noticed the front axle was hot where the diff is.
When I did the bearing I checked the front diff oil and nothing came out so I've now got oil in there. With the front oil seals leaking onto the balls I just thought oil level was ok.
So.I have a wine on the front diff and the diff is getting hot when working hard. Obviously I need a diff to go in.
Question is.
Would the diff be making so much heat to cause smoke to come out the breathers?
What else could it be? Bearing,I doubt it. Sticking Caliper,don't think so.
Anyone with any ideas? Thanks
Question is.
