- May 26, 2014
woke up christmas morning to find a chinese double din head unit with sat nav reverse cam etc at the bottom of the bed.
fitted the head unit and everything works fine. got on the reverse cam today. i wanted the camera to come on in reverse and when the av screen is selected so i have the cam live connected to the acc connection, earthed at the number plate light earth. i also have a wire going from the reverse light positive to the reverse signal wire coming off the head unit. so when i put the vehicle in reverse the camera comes on as it should, but when i select the av screen it says there is no signal, interestingly if i plug the av lead into the video input socket on the back of the head unit instead of the reverse socket i get a picture, but then it wont work when put in reverse! stating no signal!
its cold and dark and now im out of ideas..
