Hi
i don't know how to get the cover off it should pop out from one end. But I do want to say don't put a bulb in put a led globe they are just chalk n cheese you won't believe how bright they are. Jaycar or 12 volt shops have them
Two screws inside the pop down glasses case, then pull down the rear of the light assembly. It is held in with two panel clips at the rear, but they take a bit off pulling!
