Chas
Cheers Tony, will you be supplying a map?TonyS said:Hi,
Just to mention all the punches will be put out using my old 1983 hilux, so should all be ok to get, once you find them.
Ian Rubie said:What he did not say was the hilux will be towed to the location of the punches using a 500hp 4wd tractor that is laying around the farmTonyS said:Just to mention all the punches will be put out using my old 1983 hilux, so should all be ok to get, once you find them.
Are you going to come and have a play with your new winch?Crispin said:I'll be ok then here I was worried I would be bored.
Are you going to come and have a play with your new winch?[/quote:450b4omi]Jon Wildsmith said:[quote="Crispin":450b4omi]I'll be ok then here I was worried I would be bored.
I am sure we can find you a nice flat piece of grassCrispin said:Well, I need to get stuck first
From the conversation I had with Tony on Saturday there should be a place in the woods you can test your winch *before* you get stuck I will be testing mine there, single and double line pulls, repeatedly, and monitoring the motor temperature and get this big question mark that's in my mind resolved one way or the other.Crispin said:Well, I need to get stuck first
Cossack said:Cheers Tony, will you be supplying a map?TonyS said:Hi,
I meant of the punches, just for us old fogeys with failing eyesightTonyS said:Hi Chas,
Yes, maps provided, and general areas marked where you can go.
My little leaf sprung lux shouldn't be too hard to follow, even if its a bit wet,
